Content Browser panel
To open the Content Browser panel:
  • Run the CONTENTBROWSEROPEN command.
  • Right-click a ribbon panel or toolbar and choose Content Browser from the Panels list.
The Content Browser panel allows you to quickly open drawings, manage block libraries, copy dimension styles and place views from any DWG files stored on your computer.
  1. Add Folder…
  2. Refresh
  3. Definitions in the selected drawing
  4. Local Folders tree
  5. Definitions’ preview
  6. Description
Add folder…
Displays the Choose a folder dialog box.
Refresh
Select a drawing and press the Refresh button to expand its content (Blocks, Dimension Styles, Model Views).
Select Blocks/Dimension styles/Model views to see the definitions used within the drawing.
You can drag & drop a block onto the current drawing and an Insert Block dialog box will appear.
You can drag & drop a dimension style into the current drawing. If a dimension style with the same name already exists, a Copy / Paste dialog box will appear.
You can drag & drop a model view into the current drawing. This option is available only in Paper Space.
Local Folders tree
Displays the content of a drawing/project. Right-click menus enable you to add or remove folders from within the Folders tree.
Shows a preview of your drawing/block/dimension style.
Displays a description of your selected definition.
