3DCOMPAREMODE system variable
Compare mode
Controls the visualization for the 3DCOMPARE command.
When the third option is used (to show both models in one viewport), the two other options become irrelevant and are not taken into account.
BricsCAD only
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
0 to 7 |
| Default value: |
3 |
| Possible values: |
0: Do not show any differences between the first and second models. 1: Show differences in first model, on the left 2: Show differences in second model, on the right 4: Show both models with differences in one viewport |
