ACISHLRRESOLUTION system variable
Hidden line removal resolution
Controls the smallest distance used for Hidden Line Removal calculation.
Negative value is Auto-calibration based on the size of the model (recommended). For very small entities the value can be set to 0.001 or smaller.
BricsCAD only
| Type: |
Real |
| Saved in: | Preference |
| Default value: |
-1.0 |
