ANNOMONITOR system variable
Annotation monitor
Turns the annotation monitor on or off. When ON, a warning sign is displayed near the disassociated dimension.
| Type: |
Short |
| Saved in: |
Drawing |
| Default value: |
-2 |
| Possible options: |
-2: Annotation monitor is Off, any Model Documentation edit and update events automatically changes the value to 2. The status bar control toggles between 2 and -2. -1: Annotation monitor is Off. The status bar control toggles between 1 and -1. 0: Annotation monitor is Off. 1: Annotation monitor is On. The status bar control toggles between 1 and -1. 2: Annotation monitor is On. The status bar control toggles between 2 and -2. |
