The Status Bar
To display the Status Bar, do one of the following:
  • Move the cursor over a docked toolbar, the ribbon or a panel icon, then right-click and choose Status Bar in the context menu.
  • Press the Shift + F3 keyboard shortcut.
The Status Bar closes if it open, and vice versa.
Note: By default, the new Status Bar is activated (USENEWSTATUSBAR system variable value is On).
The new Status Bar
The new Status Bar displays the Model and Layout tabs (1) and the Status Bar section (2) in one line.
  1. Model and Layouts tabs
  2. Status Bar section
Displays the Model and Layout tabs.
  1. Manage Model and Layouts menu
  2. Model and Layout tabs
Manage model and layouts menu
Opens the manage model and layouts menu that allows you to create, copy and delete layouts.
  1. Search
  2. Publish
  3. Add new layout
  4. Copy selected layout(s)
  5. Delete one or multiple layouts
  6. Move up
  7. Move down
  8. Page Setup
  9. Dock inline with status bar button
  10. Model and layouts list
Search
Searches for a layout name and displays only the searched layout. This is useful when a drawing contains many layouts.
Publish
Opens the Publish dialog box.
Add new layout
Adds a new layout to the list.
Copies the selected layout(s) to the list.
Deletes one or multiple layouts in the list.
Move up
Moves the selected layouts up the list.
Move down
Moves the selected layouts down the list.
Page setup
Opens the Page Setup dialog box.
Toggles the display of the Model and Layout tabs inline or above the Status bar.
If turned on, the Model and Layout tabs are displayed inline with the Status bar, to leave more space for the drawing area.
If turned off, the Model and Layout tabs are placed above the Status bar.
Lists the Model and available Layouts.
Note:
  • When you right-click a layout name, a context menu opens with the following options: Rename Layout, Copy Layout, Publish, and Delete.
  • The current layout is marked in the list with a blue dot.
  • Click in front of the layer name and icon to set it as the current layout.
  • Double-click a layout name to rename it.
Note: The LAYOUTMANAGER command opens the Layout Manager dialog box that allows you to create, copy and delete layouts.
Displays the Model and Layout tabs. Right-click a layout to open a context menu with the following options:
New Layout
Creates a new layout and adds it at the end of the tabs list.
From template
Creates a new layout from a template file chosen from the Select Template From File dialog box.
Delete
Deletes the layout.
Rename
Renames the layout.
Copy
Makes a copy of the layout and adds it after the layout in the tabs list.
Move left
Moves the layout to the left in the tabs list.
Move right
Moves the layout to the right in the tabs list.
Page setup
Print
Opens the Print dialog box.
Export
Exports the layout to a specified drawing chosen from the Export Layout to drawing dialog box.
Status Bar section
  1. Visible tool
  2. Drop-down button
  3. Status Bar menu
Click a visible tool(1) on the Status Bar to toggle it on or off. Right-click a visible tool (1) or click the drop-down button (2) to display a context menu or settings for that tool.
Visible tool
Displays the visible tool on the Status Bar and provides quick access to it. Click a visible tool to toggle it on or off. Right-click some of the visible tools to open a context menu that displays the Settings... option and/or other options.
Note:
  • Hover over a visible tool to display its name and description.
  • For the narrow BricsCAD windows, visible tools are displayed as icons.
Drop-down button
Displays a context menu with options for the tool.
Status Bar menu
Displays the Configure Status Bar list of available tools for the Status Bar. Click an item in the list to toggle the display of the corresponding tool in the Status Bar. The position of a tool in the Configure Status Bar list corresponds to the position of the tool in the Status Bar. Customization and settings options are available for each tool in the Status Bar, either from the drop-down button or by right-clicking.
Available tools in the Status Bar
Cursor Coordinate Values
Displays the coordinates of the current cursor position (depending on the value of the COORDS system variable).
Click the tool in the Status Bar to open a context menu. It allows you to change the linear units, and coordinate settings.
GIS Coordinate System
Displays the name of the current GIS coordinate system.
Click the button to open the Geographic Location dialog box.
Paper/Model
Allows you to switch between model space and paper space or viewports or layouts.
  • When working in Model Space, the tool reads:
    MODEL (= model space with tiled viewports).
    Click to switch to the most recently opened paper space layout.
  • When working in a layout, the tool reads:
    M:Layout: model space with floating viewports
    or
    P:Layout: paper space.
    Click the tool to toggle between paper space and model space with floating viewports.
Current Layer
Displays the name of the current layer.
  • Click to open a pop-up list with all available layers.
  • Click to select the current layer in the pop-up list.
  • Click the buttons to toggle each layer property.
Current Color
Displays the current color.
  • Click to open a pop-up list with colors options.
  • Click to select the current color in the pop-up list.
  • Click the Select color option to open the Color dialog box.
Current Linetype
Displays the name of the current linetype.
  • Click to open a pop-up list with the linetypes options.
  • Click to select the current linetype in the pop-up list.
  • Click the Load option to open the Load Linetypes dialog box.
  • Click the Properties option to open the Drawing Explorer > Linetypes dialog box.
Current Text Style
Displays the name of the current text style.
  • Click to open a pop-up list with the text styles options.
  • Click to select the current text style in the pop-up list.
  • Click the Properties option to open the Drawing Explorer > Text Styles dialog box.
Current Dimension Style
Displays the name of the current dimension style.
  • Click to open a pop-up list with the dimension styles options.
  • Then, click to select the current dimension style in the pop-up list.
  • Also, click the Properties option to open the Drawing Explorer > Dimension Styles dialog box.
Grid
Indicates the status of the GRIDMODE system variable.
  • Click to toggle the display of grid in the current viewport.
  • Right-click and choose Settings in the context menu to edit the Snap and Grid settings.
Snap
Indicates the status of the SNAPMODE system variable.
  • Click the tool to toggle SNAPMODE On/Off.
  • Click the drop-down button and click to select the current SNAPTYPE system variable option in the pop-up list.
  • Click the drop-down button and choose Settings in the pop-up list to edit the Snap and Grid settings.
Dynamic Input (DYN)
Indicates the status of the DYNMODE system variable.
  • Click to toggle the display of Dynamic Dimensions On/Off.
Ortho
Indicates the status of the ORTHOMODE system variable. Turning on Ortho automatically turns off Polar.
  • Click to toggle ORTHOMODE On/Off.
  • Right-click and choose Settings in the context menu to edit the ORTHOMODE system variable.
Polar
Toggles the Polar Tracking option of the AUTOSNAP system variable.
  • Click to toggle Polar Tracking On/Off. Turning on Polar automatically turns off Ortho.
  • Click the drop-down button and click to select the current POLARANG system variable options in the pop-up list.
  • Click the drop-down button and choose Settings in the pop-up list to edit the Polar Tracking settings.
STrack
Indicates the status of the Entity Snap Tracking option of the AUTOSNAP system variable.
  • Click to toggle Entity Snap Tracking On/Off.
  • Right-click and choose Settings in the context menu to edit the Snap Tracking settings.
ESnap
Indicates the status of the Entity Snap option of the OSMODE system variable.
  • Click to toggle Entity Snaps On/Off.
  • Click the drop-down button to open the Entity Snapping Settings pop-up list and click to activate the Entity Snaps options.
  • Choose Settings in the pop-up list to edit the 2D and 3D Entity Snaps settings.
Lineweight (LWT)
Indicates the status of the LWDISPLAY system variable.
  • Click to toggle the display of line weights On/Off.
Selection Cycling
Indicates the status of the SELECTIONCYCLING system variable.
  • Click to toggle the display of Selection Cycling On/Off.
  • Click the drop-down button and click to select the current SELECTIONCYCLING system variable options in the pop-up list.
  • Click the drop-down button and choose Settings in the pop-up list to edit the Selection cycling settings.
Selection Modes
Indicates the status of the SELECTIONMODES system variable.
  • Click to toggle the display of Selection Modes On/Off.
  • Click the drop-down button and click to select the current SELECTIONMODES system variable options in the pop-up list.
  • Click the drop-down button and choose Settings in the pop-up list to edit the Selection modes settings.
Dynamic UCS (DUCS)
Indicates the status of the UCSDETECT system variable.
  • Click to toggle the UCSDETECT system variable On/Off.
  • Click the drop-down button and click to select the supported entity types in the pop-up list:
    • DUCS on Faces of 3D Solids: 3D solid faces and regions.
    • DUCS on Other Entities: 2D linear entities.
  • Click the drop-down button and choose Settings in the pop-up list to edit the UCS detect settings.
AutoScale
Indicates the status of the ANNOAUTOSCALE system variable. When On, annotative entities are synchronized with the current annotation scale. Click the tool to toggle ANNOAUTOSCALE On/Off.
Annotation Scale
Displays the value of the CANNOSCALE (= current annotation scale) system variable. Click the drop-down button to open the pop-up list:
  • Select an annotation scale in the list.
  • Custom: opens the Edit Scale List dialog box.
  • Hide Xref scales: lists annotation scales of the current drawing only.
Annotation monitor
Indicates the status of the ANNOMONITOR system variable.
  • Click to toggle the ANNOMONITOR On/Off.
  • Right-click and choose Settings in the context menu to edit the Annotation monitor settings.
Viewport Lock (VPLOCK)
Displays the status of Display Locked property of the current viewport or the selected viewport(s). Click the VPLOCK tool to toggle the property On/Off.
The VPLOCK tool only appears when one or more paper space viewports are selected or when a viewport is active (model space with floating viewports).
Viewport Standard Scale
Allows you to conveniently set the scale of the selected layout viewport relative to paper space.
Tablet
Initializes the use of a drawing tablet.
Right-click and choose Settings in the context menu to edit the Tablet mode settings.
Quad
Indicates the status of the QUADDISPLAY system variable.
  • Click to toggle the display of the Quad On/Off.
  • Click the drop-down button and click to select an option in the pop-up list.
    • Show Quad on Hover
    • Show Quad on Select
    • Show Quad on Right Click
    • Suppress Quad on Hover When Entities are Selected
    • On/Off
    • Customize Quad Items…: Displays the Customize > Quad dialog box
    • Settings…: Displays the Settings - Quad display dialog box
Rollover tips (RT)
Indicates the value of the ROLLOVERTIPS system variable.
  • Click to toggle the display of rollover tips.
  • Click the drop-down button and click to select the available rollover tips display options in the pop-up list:
    • Show Rollover when Hovering Entities
    • No Rollover tips
    • Show Block Parameters
  • Click the drop-down button and choose Customize… in the pop-up list to open the Customize > Properties dialog box. Here you can define which properties are displayed in the Rollover Tips for each entity type.
Hide/Isolate Entities
Highlights only when there are hidden objects in the drawing.
  • Click the tool to open the options:
    • Isolate: launches the ISOLATEOBJECTS command.
    • Hide: launches the HIDEOBJECTS command.
    • Show All: launches the UNISOLATEOBJECTS command.
Hotkey Assistant (HKA)
Indicates the value of the HOTKEYASSISTANT system variable. When switched On, an assistant widget at the bottom of the screen reveals the available options. Press the Ctrl key to cycle through the options.
  • Click to toggle the display of the HKA widget On/Off.
  • Right-click and choose Configure option in the context menu to display the Hotkey Assistant Configuration dialog box. Select the commands for which you want the HKA widget to display.
Current Workspace
Displays the name of the current workspace.
  • Click to set the value of the WSCURRENT system variable in the Command line.
  • Click and choose the current workspace in the pop-up list.
  • Choose Customize in the pop-up list to open the Customize > Workspaces dialog box.
Lock User Interface (LOCKUI)
Allows you to lock the location and size of toolbars and dockable panels.
  • Click to toggle the lock On/Off.
  • Click the drop-down button to display a pop-up list.
    • Select the UI items to lock: toolbars, panels or both.
    • Choose Settings… to set the value of the LOCKUI system variable in the Settings dialog box.
Publish Monitor
Manages the publishing process. The button is highlighted while publish is in progress.
Click the drop-down button to display the pop-up list:
  • Cancel the job: cancels the ongoing publish job.
  • Publish: opens the Publish dialog box.
  • Show publish log: opens the Publish Output dialog box.
Show Notifications
Toggles the displaying of the notifications.
The old Status bar
Setting the USENEWSTATUSBAR system variable to Off returns the old Status Bar.
  1. Status field
  2. Field List button
Status field
  • Displays the status of the software.
  • When the cursor is in a menu or on a toolbar, it gives a brief description of the tool or menu item under the cursor.
  • When the Command line is closed, it displays the command prompts, tool options and keyboard entry.
  • Double-click the status field to open or close the Command line.
Field List button
Click the arrow button () to display a list of available Status Bar fields. Click an item in the list to toggle the display of the corresponding field in the Status Bar.
Tip: Right-click a field to open a context menu with more options.
