ARRAYASSOCIATIVITY system variable
Associative arrays
Creates new arrays as associative arrays.
Type:
Boolean
Saved in:
Registry
Default value:
On
Possible values:
Off (0): Not associative
On (1): Associative
Related commands
  • ARRAY command
  • -ARRAY command
  • ARRAYCLASSIC command
  • ARRAYCLOSE command
  • -ARRAYCLOSE command
  • ARRAYEDIT command
  • ARRAYPATH command
  • ARRAYPOLAR command
  • ARRAYRECT command
