BASEFILE system variable
Template
The file path and default template file name for new drawings. If empty, uses built-in defaults.
BricsCAD only
Type:
String
Saved in:
Registry
Note:
When the BASEFILE system variable is set to none or no drawing template is found in the folder specified by the TEMPLATEPATH system variable, clicking the New drawing button from the Start page displays the Create New Drawing dialog box.
When the BASEFILE system variable is set to none or no drawing template is found in the folder specified by the TEMPLATEPATH system variable, launching the QNEW command takes you back to the Start page to select a template. The selected template overrides the current value of the BASEFILE system variable.
