BDEPENDENCYHIGHLIGHT system variable
Highlight dependent objects
Highlights all objects that are dependent on a selected action or parameter in the Block Editor.
Type:
Boolean
Saved in:
Registry
Default value:
On
Possible values:
Off (0): Dependent objects are not highlighted when an action or parameter is selected.
On (1): Dependent objects are highlighted when an action or parameter is selected.
