BEDITASSOCMODE system variable
Associative identifiers in BEDIT
Controls if additional service data is generated during the BEDIT command.
This enables the automatic re-association of constraints and dimensions attached to the references of the block, including references in other documents.
BricsCAD only
Type:
Boolean
Saved in:
Registry
Default value:
1
Possible values:
0: Do not initialize identifiers in BEDIT
1: Initialize identifiers in BEDIT
