BEDITMODE system variable
Block editor mode (Read Only)
The Block Editor can be opened to edit standard static and dynamic blocks or blocks with parametric data (specific to BricsCAD).
BricsCAD only
Important: Editing of dynamic blocks is not possible on United States territory. In the event that you purchase BricsCAD in the U.S. or for use in the U.S., this feature is neither available nor licensed to you. Please see EULA for more information.
Type:
Short
Saved in:
Not saved
Possible options:
0: BEDIT not open
1: General (BricsCAD parametric data is not allowed)
2: Allow BricsCAD parametric data
3: No restrictions
