BLOCKEDITOR system variable
Block editor (Read Only)
Shows if the Block Editor (BEdit mode) is open or not.
Type:
Boolean
Saved in:
Not saved
Possible values:
(0): The Block Editor is not open.
(1): The Block Editor is open.
Related commands
  • BEDIT command
  • BESETTINGS command
Related variables
  • BEDITMODE system variable
  • BLOCKEDITLOCK system variable
