BOMPROPERTYSET system variable
Default BOM property set
Sets the default set of properties for BOM tables.
BricsCAD only
| Type: | Short |
| Saved in: | Registry |
| Range: | 0 to 3 |
| Default value: | 1 |
| Possible values: | 1: Mechanical-only properties 2: All properties except coordinates 3: All properties |
Note: If the BOM filter mode requires to include non-mechanical objects (BOMFILTERSETTINGS = 2 / 4 / 6)), then the property set will be automatically extended to include all properties except coordinates (BOMPROPERTYSET=2).
