COMMANDASSIST system variable
AI Predict Command line
Controls the use of personalized, AI command suggestions.
Only possible if Application Data collection is enabled in the DATACOLLECTIONOPTIONS system variable.
BricsCAD only
Type:
Boolean
Saved in:
Preference
Range:
Off
Possible values:
Off (0): Do not enable AI Predict Command line
On (1): Enable AI Predict Command line
