COMMANDPREVIEW system variable
Enables a preview of the outcome of commands such as TRIM, EXTEND.
If CommandPreview is enabled then some commands will display a preview of their expected results.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Preference |
| Default value: |
On |
| Possible values: |
Off (0): Do not enable preview in commands On (1): Enable preview in commands |
