COMPONENTSCONFIG system variable
Library Panel Configuration
The name of the active Library panel configuration file. Controls what is shown in the Library panel.
Use the SRCHPATH command to find the file.
BricsCAD only
Type:
String
Saved in:
Workspace
Related commands
  • -CREATELIBRARYBLOCK command
Related variables
  • SRCHPATH system variable
Related information
  • Library panel
