DIMSTYLE system variable
Dimension style (Read Only)
The current dimension style.
Type:
String
Saved in:
Drawing
Default value:
Standard
Related commands
  • DIM command
  • DIMSTYLE command
  • QDIM command
Related variables
  • DIMDLI system variable
  • DIMLAYER system variable
Related information
  • Hotkey Assistant widget
  • Dimensioning tools overview
  • Working with dimension styles
