DIMSTYLE system variable Dimension style (Read Only) The current dimension style. Type: String Saved in: Drawing Default value: Standard Parent topic: System variable referenceRelated commandsDIM commandDIMSTYLE commandQDIM commandRelated variablesDIMDLI system variableDIMLAYER system variableRelated informationHotkey Assistant widgetDimensioning tools overviewWorking with dimension styles
