DRAWINGPATH system variable
Drawings path
The file path used for the fifth folder on the left of the OPEN, SAVEAS and INSERT command dialogs (Windows only).
BricsCAD only
Type:
String Standard
Saved in:
Preference
Related commands
  • DIST command
  • INSERT command
  • OPEN command
  • SAVEAS command
Related information
  • Generic Open file dialog box
