DRAWINGVIEWFLAGS system variable
Drawing View Flags
Enables the parallel generation and update of views created with the VIEWBASE command.
BricsCAD only
| Type: |
Short |
| Saved in: |
Registry |
| Default value: |
Off |
| Possible values: |
Off (0): Disabled parallel generation and update of views On (1): Enabled parallel generation and update of views |
