DRAWINGVIEWQUALITY system variable
Quality of drawing views
Controls the quality of views created with the VIEWBASE command.
Turn off to significantly reduce the time needed to generate drawing views. Views with draft-quality geometry are created, it is not possible to put annotations on the edges of entities in these views.
However, they look very similar to a precise (high-quality) drawing view and you can use them to quickly create layouts.
Type: |
Short |
Saved in: |
Drawing |
Range: |
0 to 1 |
Default value: |
1 |
Possible values: |
0: Draft quality 1: High quality |
