EXPERIMENTALMODE system variable
Enable experimental features
You may experience bugs or performance issues in BricsCAD when the experimental mode is enabled. We encourage you to report them. Experimental features can change or be removed from future versions.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: | 0 |
| Possible values: |
0: Disable the Experimental mode 1: Enable the Experimental mode |
