EXPERIMENTALMODE system variable
Enable experimental features
You may experience bugs or performance issues in BricsCAD® when the experimental mode is enabled. We encourage you to report them. Experimental features can change or be removed from future versions.
BricsCAD only
Type: |
Boolean |
Saved in: |
Registry |
Default value: | 0 |
Possible options: |
0: Disable the Experimental mode 1: Enable the Experimental mode |
