EXTRUDEOUTSIDE system variable
Extrude behavior outside
Controls how new entities, modify a parent entity when they touch. Applies to entities as they are created with the EXTRUDE and REVOLVE commands, when the Auto option is selected.
A parent entity is any entity that touches the contour from which extruded/revolved entity was created.
The EXTRUDEOUTSIDE system variable is one of the four system variables found under the Extrude mode group.
BricsCAD only
| Type: | Short |
| Saved in: | Workspace |
| Range: | 0 to 2 |
| Default value: | 0 - for Workspaces Drafting and Modeling 1 - for Workspaces Mechanical and BIM |
| Possible options: | 0: Do not modify 1: Subtract the new entity from the existing entity 2: Unite the entities |
