FACETRES system variable
Facet resolution
Controls the smoothness of shaded, rendered and hidden line views.
Values between 0.01 and 10.0 are accepted. Large values can have a significant impact on memory usage and performance.
Type:
Real
Saved in:
Drawing
Range:
0.01 to 10.0
Default value:
0.5
Related commands
  • MODELERPROPERTIES command
  • -MODELERPROPERTIES command
  • SHADE command
  • STLOUT command
  • -SHADEMODE command
  • SHADEMODE command
