GRIDUNIT system variable
Grid unit
Controls the X and Y grid spacing for the current viewport.
Type:
2D point
Saved in:
Drawing
Default value:
0.5, 0.5
Note: The default value applies when the MEASUREMENT system variable is set to 0 and the INSUNITS system variable is set to inches. When the MEASUREMENT system variable is set to 1 and the INSUNITS system variable is set to millimeters, the default value is 10, 10.
