SNAPUNIT system variable
Snap unit
Controls the current viewport's snap spacing. Adjusts itself automatically to reflect the isometric snap, if SNAPSTYL is set to Isometric snap (1).
Note: There is no snap in the Z direction.
Type:
2D point
Saved in:
Drawing
Default value:
0.5, 0.5
Note: The default value applies when the MEASUREMENT system variable is set to 0 and the INSUNITS system variable is set to inches. When the MEASUREMENT system variable is set to 1 and the INSUNITS system variable is set to millimeters, the default value is 10, 10.
