GRIDUNIT system variable
Grid unit
Controls the X and Y grid spacing for the current viewport.
| Type: |
2D point |
| Saved in: |
Drawing |
| Default value: |
0.5, 0.5 Note: The default value applies when the MEASUREMENT system variable is set to 0 and the INSUNITS system variable is set to inches. When the MEASUREMENT system variable is set to 1 and the INSUNITS system variable is set to millimeters, the default value is 10, 10.
