HLRNEXTGEN system variable
Next generation hidden line removal
Speed up parallel hidden line removal by using an experimental next generation algorithm.
BricsCAD only
Type:
Boolean
Saved in:
Registry
Default value:
Off
Possible values:
Off (0): Don’t use next generation algorithm to speed up hidden line removal
On (1): Use next generation algorithm to speed up hidden line removal (Experimental)
