HOTKEYASSISTANT system variable
Hotkey Assistant
Displays the Hotkey Assistant.
The Hotkey Assistant appears in the bottom-middle of the screen and displays keyboard shortcut tips, during some commands.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: |
On |
| Possible values: |
Off (0): Don’t show Hotkey Assistant On (1): Show Hotkey Assistant |
