IFCEXPORTBASEQUANTITIES system variable
Export base quantities
Export derived base quantities (quantities calculated from two or more measurements) from BIM entities during IFC export.
BricsCAD only
Type: |
Boolean |
Saved in: |
Registry |
Default value: | 0 |
Note: Ply quantities are exported when both IFCEXPORTMULTIPLYELEMENTSASAGGREGATED and IFCEXPORTBASEQUANTITIES system variables are set to ON. For IFC4 Reference View file, next to the quantities for the wall as a whole, the ply quantities are exported as a sub set for each ply (as IfcPhysicalComplexQuantity).
