IFCEXPORTMULTIPLYELEMENTSASAGGREGATED system variable
Export multi-ply elements as aggregated elements
Export multi-ply elements as aggregated elements.
BricsCAD only
Type:
Boolean
Saved in:
Registry
Default value: 0
Note: Ply quantities are exported when both IFCEXPORTMULTIPLYELEMENTSASAGGREGATED and IFCEXPORTBASEQUANTITIES system variables are set to ON. For IFC4 Reference View file, next to the quantities for the wall as a whole, the ply quantities are exported as a sub set for each ply (as IfcPhysicalComplexQuantity).
