IFCEXPORTMULTIPLYELEMENTSASAGGREGATED system variable
Export multi-ply elements as aggregated elements
Export multi-ply elements as aggregated elements.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: | 0 |
Note: Ply quantities are exported when both IFCEXPORTMULTIPLYELEMENTSASAGGREGATED and IFCEXPORTBASEQUANTITIES system variables are set to ON. For IFC4 Reference View file, next to the quantities for the wall as a whole, the ply quantities are exported as a sub set for each ply (as IfcPhysicalComplexQuantity).
