IFCSETTINGSCONFIG system variable
IFC settings configuration
Specifies the name of the IFC settings configuration file.
BricsCAD only
Type:
String
Saved in:
Registry
Default value: "bim_ifc_settings.xml"
Related commands
  • IFCEXPORT command
  • -IMPORT command
  • IMPORT command
Related information
  • Export To IFC dialog box
  • IFC Import Settings dialog box
