IMPORTCATIAV5SEARCHPATHSPREFERENCE system variable
Search paths preference
Defines priority order of search paths.
Note: This option is taken into account only when import in
                    background is enabled (CommunicatorBackgroundMode system variable is ON).
            BricsCAD only
| Type: | Short |
| Saved in: | Registry |
| Range: | 1 to 3 |
| Default value: | 1 |
| Possible options: | 1: Sub-folders first 2: Root folder only 3: Root folder first |
