IMPORTSIMPLIFY system variable
Perform simplification
Automatically runs the DMSIMPLIFY command on imported models. See also the IMPORTIGESSIMPLIFY system variable.
Note: The IMPORTIGESSIMPLIFY system variable can set an override for the IGES file format.
- Convert imported splines into canonical surfaces.
- Simplify topology (remove imprinted edges) if possible.
BricsCAD only
Type: |
Boolean |
Saved in: |
Registry |
Default value: | 0 |
