LOFTNORMALS system variable
Loft normals
Controls the behavior of surfaces and solids created with the LOFT command as they pass through a cross section.
| Type: | Short |
| Saved in: | Drawing |
| Range: |
0 to 6 |
| Default value: |
1 |
| Possible values: |
0: Ruled surface 1: Smooth surface 2: Surface is perpendicular to the first cross section 3: Surface is perpendicular to the last cross section 4: Surface is perpendicular to the first and last cross sections 5: Surface is perpendicular to all cross sections 6: Surface uses draft angle and magnitude |
