MASSPREC system variable
Mass precision
Controls the number of decimal places displayed for masses, if mass properties are formatted with the PROPUNITS system variable.
Note: If negative, LUPREC (Linear Unit Precision) is used.
BricsCAD only
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
-1 to 8 |
| Default value: |
-1 |
| Possible options: |
-1: Use LUPREC 0: 0 1: 0.0 2: 0.00 3: 0.000 4: 0.0000 5: 0.00000 6: 0.000000 7: 0.0000000 8: 0.00000000 |
