MEASUREMENT system variable
Measurement
Controls the current drawing units as Imperial or Metric, also controls if ANSI or ISO hatch pattern and linetype files are used. See also the LUNITS and INSUNITS system variables.
| Type: |
Short |
| Saved in: |
Drawing |
| Range: |
0 to 1 |
| Default value: |
1 |
| Possible options: |
0: Imperial (use ANSI Hatch and ANSI Linetype) 1: Metric (use ISO Hatch and ISO Linetype) |
