PARAMETRIZECONNECTIONS system variable
Parametrize Connections
Controls if constraints connect components for the BMCONVERT, BMCONNECT and BMINSERT (SMART insert option) commands.
BricsCAD only
Type:
Boolean
Saved in:
Registry
Range:
0 to 1
Default value:
1
Possible values:
0: Don't use constraints
1: Use constraints
