PBLOCKREFERENCEOPERATIONSVISUALIZATION system variable
Visualize parametric operations on block references
Enables the visualization of the parametric operations' information when hovering the cursor over parametric block references.
BricsCAD only
Type: |
Boolean |
Saved in: |
Registry |
Default value: |
Off |
Possible values: |
Off (0): Visualization off On (1): Visualization on |
