PDFPAPERHEIGHT system variable
PDF override - paper height
Paper height for PDF export, in millimeters, if the PDFPAPERSIZEOVERRIDE system variable is on (1).
BricsCAD only
Type:
Short
Saved in:
Preference
Default value:
297
Related commands
  • PDFOPTIONS command
Related variables
  • PDFPAPERSIZEOVERRIDE system variable
  • PDFPAPERWIDTH system variable
