PDFPAPERWIDTH system variable
PDF override - paper width
Paper width for PDF export, in millimeters, if the PDFPAPERSIZEOVERRIDE system variable is on (1).
BricsCAD only
Type:
Short
Saved in:
Preference
Default value:
210
Related commands
  • PDFOPTIONS command
Related variables
  • PDFPAPERHEIGHT system variable
  • PDFPAPERSIZEOVERRIDE system variable
