PDMODE system variable
Point display mode
Controls the display style for point entities.
| Type: |
Short |
| Saved in: |
Drawing |
| Range: |
0 to 100 |
| Default value: |
0 |
| Possible options: |
1: none 0: . 2: + 3: x 4: ' 32: circle 64: square |
Different geometric representations of point entities are provided by values of 0, 2, 3, and 4. You can choose only one options between them. When the value is 1, nothing is shown.
In addition to the geometry drawn by the value 0, 2, 3, or 4, the values 32 or 64 specify a shape that can be drawn around it.
