PLINETYPE system variable
Polyline type
Controls how polylines are created with the PLINE command and if old-format polylines are converted.
It saves disk space and memory by using the optimized format.
| Type: | Short |
| Saved in: | Registry |
| Range: | 0 to 2 |
| Default value: | 2 |
| Possible values: | 0: Old-format polylines are not converted; PLINE creates old-format polylines 1: Old-format polylines are not converted; PLINE creates optimized polylines 2: Old-format polylines are converted; PLINE creates optimized polylines |
