POINTCLOUDHSPC system variable
HSPC mode
Toggles the format used to preprocess point clouds HSPC/BCAD.
Note: The HSPC file format (Hexagon Smart Point Cloud) is a proprietary format developed by Hexagon VCH (Visual Computing Hub). Using this format enables storing per point information which will be used to have more point cloud functionalities (in the future).
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Preference |
| Default value: |
On |
| Possible values: |
Off (0): Use BCAD to preprocess point clouds. On (1): Use HSPC to preprocess point clouds. |
