POINTCLOUDRENDERMODE system variable
Render mode
Controls the render mode of the point cloud.
BricsCAD only
| Type: |
Short |
| Saved in: |
Preference |
| Range: |
0 to 2 |
| Default value: |
1 |
| Possible options: |
0: Default 1: Dollhouse - hides points with normal pointing away from the camera view direction 2: Outline - only visualizes points with normal perpendicular to camera view direction |
