POINTCLOUDSHOWBUBBLES system variable
Bubble display mode
Controls the display mode of the bubbles.
BricsCAD only
Type:
Short
Saved in:
Preference
Range:
0 to 2
Default value:
1
Possible options:
0: Off
1: On
2: Visible only
Related commands
  • POINTCLOUD command
  • POINTCLOUDATTACH command
  • -POINTCLOUDATTACH command
  • POINTCLOUDCOLORMAP command
  • POINTCLOUDCROP command
  • POINTCLOUDDETECTFLOORS command
  • POINTCLOUDFITPLANAR command
  • POINTCLOUDPROJECTSECTION command
Octave
