POLARADDANG system variable
Polar add angles
Contains a list of custom polar snap angles, if the POLARMODE system variable is set to Use additional polar tracking angles.
Up to 10 angles, up to 25 characters each, separated with semicolons (;).
Requires POLARMODE flag 0x04 to be set (Use additional polar tracking angles). The AUNITS system variable sets the format for display of angles. Unlike POLARANG, POLARADDANG angles do not result in multiples of their values.
Type:
String
Saved in:
Registry
