PSLTSCALE system variable
Paper space linetype scale
Controls the linetype scaling in paper space. If Viewport scaling governs linetype scaling is active, the length of the dashes is based on paper space drawing units - linetypes display identically, in all viewports, even if scaled differently.
A REGEN is required.
| Type: |
Short |
| Saved in: |
Drawing |
| Range: |
0 to 1 |
| Default value: |
1 |
| Possible values: |
0: No special linetype scaling 1: Viewport scaling governs linetype scaling |
