PUBLISHALLSHEETS system variable
Publish all sheets
Controls how layouts are loaded to the Publish dialog box.
If on, loads all layouts from all active drawings. If off, loads only the layouts from the current drawing.
| Type: | Boolean |
| Saved in: |
Registry |
| Default value: | On |
| Possible values: |
Off (0): Only the contents of the current document automatically load On (1): The contents of all open documents automatically load |
